Hey I have a ysi on my built 2v. It has an intercooler and a ba5000 maf blow through. Running a 7.5 lower and 2.85 top pulley. About 22 psi. What size meth nozzle should I be running, mainly going to be running meth to increase octane to run pump gas as this is a street car
How are your nozzles rated (GPH, ml/min, or CC/min) and what is your expected engine HP.
I’m not sure how they are rated I don’t have any nozzles in it yet. Well I have a cooling mist 5 in it now. Expected horsepower around 700 whp
If you have a Cooling Mist Water/Methanol Injection kit contact them, and see what they recommend for nozzles. I have no idea how they're rated, so contacting them is your best option.
Good luck
Michael Plummer
Do you have anymore feed back on this meth set up and your final numbers on the YSI. I am curious as I am running a T Trim at about 659whp and I am looking to do some changes and your set up sounds about where I wanna go.
Thanks in advance
