1 - 15 of 15 Posts
I just picked up a stock 2v 5spd gt. I'm thinking of getting a on3 kit to get my feet wet. I never had a boost combo before and I want to learn before getting a good short block. I've had some 10 sec push rod combos (one n/a and the other nitrous assisted)... My end goal is have a low low 10 sec car with basic street car amenities. Am I asking for too much? What type of combo would you go with to get a gutless 2v in the low 10's? Thanks
I'm selling my on3 turbo kit, look in power adder section on parts sale
Not cheap to make a 2v run a 10, but with a turbo kit, built block, fuel, built rear and the right cam you will see a 10 with.a good driver
keep the stock motor and put a turbo kit at 10lbs and do an auto swap and call it day.....i only say that because thats what im doing! went 11.40 with 5speed and melted clutch, now its got an auto and im itching to go to the track!
Hey that sounds like a really fun car! What et goal do you have in mind with the auto?
f-150 rear w/ 31 splines, turbo (on3?), a good cam, clutch and a tune...then hope your tranny can hold up!
As long as you go with a built shortblock to handle more boost, you can get to your goal even with stock heads. 2002 above would have gotten there with his new setup and he's on stock 2v heads as well(almost making 700rwhp). Im doing a 4v car right now with the same intentions but its all going into a foxbody.
1 - 15 of 15 Posts
