Okay, I picked up a set of used A6s and put them on my Cobra R's. I also just installed MM Fwd. Offset front control arms.
My issue:
I am rubbing the front fender liner when turning the wheel. Picture
How I think it can be fixed:
I think I can 'pull' the fender liner forward and attach it somehow...any ideas?
I haven't test fit my 255/40 17s yet, but am guessing it may hit too..
Unrelated, going to need a spacer:
I'm also going to be ordering 1/4" spacers to move the tire away from my coilover springs. They have approx. 2cm clearance right now and I know the deflection of the tire will make them touch my springs (-2.2 camber ... going to bump camber to -3) Thanks to J Rick Kirby for lending me his 1/8" and 1/4" spacers to test...
You're welcome.
Well, so much for my idea to roll the fender. Wouldn't help in this case.
I believe targeting the area of contact with "pushing" and "bracing", is your best bet. Basically the same method I used on my '66 just to clear 225/60's on 14x7's. :shakehead
While the threads are Fox related, the concept should carry over to any application.
http://forums.corral.net/forums/road-racing-auto-x/1104631-pictures-mm-k-member-w-offset-geometry-vs-standard-geometry.html
http://forums.corral.net/forums/road-racing-auto-x/1137880-mm-k-member-tire-clearance.html
And this is from the second thread below the nice picture posted by MFE.
There's a lot of great info about spreading fenders on foxbodies in this thread http://www.corner-carvers.com/forums...ad.php?t=27194 and starting at post 118 in this thread, but you have to be a member to see the pics.
HTH,
Thanks Rob. I'll check out those threads.
