Will 29.5x10.5W's fit under a mini tub. According to the M/T website, they are about the same size as a 29.5x11.5. But , I was told they are bigger. Is this true. I don't want to order the wrong tires.
I think width wise you's be fine, but the wheel well may not be big enough front to back on the car...
I'm having to trim (open up) that area on my car to fit a 315-60-15 radial. (30" tire.) Your problem is the 29.5 will grow to ?????? At the top end. So the tire will be narrower, but taller, and that's where you would see an issue.
