Anyone have either a 50mm or 35 mm pulley (with sides) 26 tooth cog for Vortech?
You can get any pulley you want custom made. The 80 tooth from the other thread and the 26 tooth you are asking about here. One potential problem with a 26 tooth blower pulley, at least with a 8mm cog belt is that it has so few teeth making contact with the blower pulley at any given time that it will tend to strip the teeth off of the belt. The faster the engine revs, the worse this problem will be. You may have to run a tougher belt (translated: more expensive) such as a Gates Polychain to avoid this problem. The Polychain belts can be $100 to $200 depending on length and width.
