1 - 20 of 44 Posts
I cant figure out this stutter. Only thing I haven't changed is spark plug wires. I don't have access to another set of wires, but I have turned out the lights and checked for arcing. I know this isn't official but that's what I have to work with. I have changed the coil, cap and rotor button, plugs and the entire fuel system is new. I have used the stock ignition table and have set all fields to 31 degrees ( locking timing ). I have been from 13.8 air fuel all the way to 15.0 air fuel. The problem is while under light load ( 45- 55 kpa 5% TPS) at 2300 -2400 rpm. Any highter or lower loading it runs fine. Anything above or below 2300-2400 its fine also. I don't know what could limit my problem to this range. I can send maps or anything you may need. Thanks in advance, Dustin Ball
I have a short one. I accidentaly erased my longer one. lol I will try to load it tonight when I get home.
Ok I cant figure out how to post a msl file. Anyone have any tips?
got a gmail account? Host it on google drive and make sure it isnt private then post up the link here.
I dont have a gmail right now but I can set one up if this is the best way. Ill give it a shot tonight.
More and less spark did not help. I added fuel until the afr was about 11.0 to 1 and it almost completely went away, but I think it was just masking the problem because it started loading my plugs. Im gonna try plug wires today and see if it helps.
Tried new plug wires and re lashed my valves, still did not help. I think I have screwed up a setting or something.
what base tune did you start with? maybe matt, jerry or one of their tech guys would take a look at the tune and log file for you by email...
Discussion Starter #12
I sent a file and datalog to Matt this morning. I bet it is something simple I am over looking.
Discussion Starter #15
Its weird because when the car went down in the winter it was running well, I know that doesnt mean anything. I have an msd box feeding a blaster coil and a msd distributor. I have replaced wires, tfi module, plugs, cap, rotor, and the coil. All of my grounds are good and I have extra grounds applied. Nothing has fixed the problem. I dont have another distributor or MSD box to try. Its weird that everything outside of the 2300-2500 rpm range at 35-40 kpa is fine. Did all of my engine settings look ok?
I actually have the same exact problem only mine is from 2,000 to 2,400 or so. Had the problem with my old turbo 302 now i have a NA 408 and the thing will just not cruse at part throttle and be smooth. My plugs are gapped around .045, I have a new distributor plug wires are good and ive tried several coils. I was going to try changing the spark hardware latency to 0 and see if that changed anything.
Discussion Starter #18
I cant remember my plug gap exactly I can check tomorrow but I think its around .042 for my n/a plugs. I write it down on my plug boxes so I dont forget them. lol I think my nitrous plugs are around .035
Discussion Starter #20
I told you wrong on my plug gap, my N/A plugs are gapped to .035 and my N20 plugs are gapped to .028
1 - 20 of 44 Posts
