Today I ran my car at Raceway Park in Old bridge N.J on a very hot day and was pleased with my results..
1st pass I held the traction switch up for 6 seconds until advance trac was totally disabled, put the trans in S and also put the car in track mode and steering in sport, I did a small burnout using the line lock and staged the car,I held the brake and got the rpms up to 1500, mashed the throttle on the 3rd yellow and cut a nice light, I hit a 2.01 60' and thats when all went to hell, the car didnt shift and seemed to bounce off the limiter which caused the car to fall flat on its face, I just coasted up to the finish at a blistering 22 seconds at 55mph.:surprise: Maybe someone can tell me what I did wrong?
2nd pass I didnt hold the traction switch or even touch it, all I did was put the car in track mode and the shifter in D, I didnt even use the line lock, I did a quick power brake to clean off the stock tires and staged the car, I raised the rpms up to 1500 again by holding the brake and applying throttle, on the third yellow I stomped the pedal to the floor, cut another good light and just hoped it would shift and not embarrass me again, this time it shifted properly and I just held on and kept her centered, I was rewarded with a very respectable 2.01 60' 12.85et at 110mph on a hot and humid day, elevation was 1584 so corrected time at sea level would be 12.628 at 112.20 if you believe the drag times calculator.>:)
3rd and final pass I was going to do everything the same as run 2 except that I would put the gear selector in S. I hit a 2.02 60' and ran 12.846 at 110.46 . The corrected times for 1325 elevation would be 12.663 at 112.078. I only posted the corrected numbers because some people and forums require a corrected time due to running in lets say Colorado and then running any of the tracks in NJ there would be a half a second difference using the same car.
Did you bump the shift paddle button on the first run and lock it in 1st?
Either way, skipping that first flubbed pass, very impressive. Congrats
Thanks, the third and final run I was up against a s550 Eco boost mustang which had a tune and some other things done, I had told the driver what happened on my first pass and he said he had something similar happen a few weeks back where his car went dumb and didn't shift which blew up his trans 2 or 3 gear. He returned his car back to stock n was lucky that ford didn't detect the car had been tuned. All in all it was a good evening.
Not buying the corrected times (they're always optimistic on my car - I need mineshaft air to hit them; never mind the high-altitude guys who never - and I mean never, in my 25 years of racing - run the number at sea level), but 110 mph in a stock, almost 4,000 lb, $30k car is amazing.
Do you think sticky tires would bring down your 60'? Were you easy on the throttle to stay out of spin? A converter and sticky tires could get you dangerously close to 11's.
