Greetings, any ideas how to fix trunk not opening with button by the license plate? Also backup camera not functioning 80% of the time. Trunk opening button on the key fob never works also. The trunk unlock button by the steering wheel works 100%.
Thanks, Jim Reno,Nevada
The back up camera is either the wiring where it flexes with trunk open/closes or a bad camera. The wiring is an easy, cheap fix if your DIY inclined, the camera is about $300 for the part and not all that hard to swap. For the trunk release I'd suspect the same wiring harness that affects the camera.
