1 - 20 of 23 Posts
2004 v6 wont start after removing dash and replacing it no fuel and cooling fan comming on dash guages acting crazy
you got the wrong dash
pats??
put a scan toll on and see uf there is comm to dash module
then you have a bad connection
put a scan tool on it
if you don't have one, take it to someone that does
there you have it
besides double checking wiring
a proper scan tool and lab scope is necessary to see the signal or lack there of
maybe you fried a module
who knows
without proper tools everything is just guess work.
update found broke wire at pats trans sponder fix it but still the same shorted fuel tank conector think i messed up pcm thats why cooling fan on can i get new pcm flashed to vin or does dealer need to program keys also swaped out ccrm
retype in somewhat legible format
or point form
did you rescan after repair?
you think?
wouldn't you rather know?
or just throw parts at?
Discussion Starter #16
well tell me the steps you would take dont want to go to dealer. ive checked fuses all good . changed ccrm because cooling fan on with key on . and found broke wire at pats transponder conection. got codes at gauge read out
first step,
is SCAN TOOL
need to KNOW what info is missing on the CAN-BUS ...
if you have a lab scope, and KNOW what the signal, digital pulses, are needed then you could try that difficult route.
you have any questions about my profile page after visiting it?
Discussion Starter #20
i dont doubt your wisdom im a simple guy trying to get simple answers .scan tool meaning obd tester???
1 - 20 of 23 Posts
