I am looking at adding NOS to my Mach 1 motor, but I do not know what to but with the kit. Can someone help me?
A little about my motor:
- 03 Mach1 4v with roughly 80k miles
- JLT CAI
- 90mm MAF from Lightning
- PaceSetter Longtubes
- Custom Catted X-Pipe
- Boral Roush Side Exhaust Mufflers
- 65mm Dual Blade TB
- Intake Manifold Spacer
- Stock Fuel Injectors
- Stock T-45
- Luke Pro Gold Stage 2 Clutch
- 4.10 Gears, 31-Spline Trac-Lock and 31-Spline Yokun Axles
Not sure how much of this is relevant, but this is what I have done minus some suspension add ons.
The kit I would be purchasing is from nitrousoutlet.com:
99-01 Cobra, 03-04 Mach 1 Mustang 4Valve Soft Line Plate System
I know that I will be buying a 10lb bottle and if I can find a 15lb cheap I will buy that.
But here is where I am lost and do not know what to add.
1.) Purge Kit
- Nitrous Outlet Big Show 4AN
- Nitrous Outlet Big Show 6AN
- Nitrous Outlet 4AN
- Nitrous Outlet 6AN
- X-Series 4AN
- X-Series 6AN
2.) Fuel Pressure Gauge (I have an autometer fuel pressure gauge so would I need this gauge?)
- 1/8 NPT Low Pressure Gauge
- Low Pressure Gauge w/ 4AN Manifold
- Low Pressure Gauge w/ 6AN Manifold
- 1/8 NPT High Pressure Gauge
- High Pressure Gauge 4AN Manifold
- High Pressure Gauge 6AN Manifold
3.) Nitrous Pressure Gauge
- 1/8 NPT Nitrous Pressure Gauge
- Nitrous Pressure Gauge w/ 4AN Manifold
- Nitrous Pressure Gauge w/ 6AN Manifold
- 1/8 NPT Digital Inline Nitrous Pressure Gauge
- Digital Inline Nitrous Pressure Gauge 4AN Manifold
- Digital Inline Nitrous Pressure Gauge 6AN Manifold
personally, if i was gonna buy their kit, i would just call them and ask about those options... Dave and his crew should have someone that can guide you thru the purchase, even if your buying online.
let me follow my last comment up by saying this... im sure everyone here will do anything we can to help you with whatever you end up buying, BUT if i was looking for a nitrous kit and asking about them on given forum, i would see what company has a rep that is easily found and active on that forum, since thats where i planned on coming for advice. Nitrous Outlet has some nice stuff as does Nitrous Express. Nitro Dave (nitrous outlet) is a member here, but hasnt been active since 2012 (last post), Nitrous Express is represented here by Garrett, he is very helpful and may be able to give you a "forum Discount". i know im always suggesting people use Garrett, that just because i want everyone to have as good of an experience using juice as i have with his help. the following link is to the products NX has for the Mach, personally i would at least contact Garrett and ask what he thought i needed and what he could do... you owe it to yourself.
Nitrous Express
