1 - 19 of 19 Posts
If it sits more more than a day or two the battery goes stone dead. Odometer has ------- across it when key is off and out of switch and the check engine light is dimly lit. The instrument cluster should not have power when key is off right? Any ideas would be helpful.
Yes, either you have a bad ignition switch or something has a short around it or the multifunction switch.
Also when running it has no check engine light and the odometer reads correctly. Starts great no dragging or anything.
before throwing parts at it
why dont you find the source of the current draw?
I am going to put my meter on it tomorrow, but I did go ahead and get the switch for 12.00 to have it with me just in case. I was just asking in hopes that someone else might have already fixed a similar problem.
Ok so #6 maxifuse under the hood is pulling 0.5 volts with key off. Owners manual says instrument cluster and pcm. Pulled fuse and car cranks but check engine light comes on and dome/trunk lights don't work. Also power locks/keyless remote stops working. The ---- on the odometer and dim check engine light went away. I left the fuse out and I'm gonna see if battery is still charged tomorrow. Any ideas?
I might pull the cluster and reinstall fuse to see if draw is still occurring with it unplugged. Every heard of a cluster being shorted causing this?
you measred a voltage potential NOT current draw
you need to find the circuits drawing current
Discussion Starter #12
My meter crapped out so I had to borrow a friends. Set on 200ma and probing across the top of the mini fuse in the interior fuse box I got 3.9.
3.9 milli amps is not a draw to worry about
are you sure its not 3.9 amps??
He went in parallel of the fuse, reading is useless.
OP, do you need more help with this? In order to read current you have to be in series with the circuit or use a dc clamp on.
Discussion Starter #15
I got a gem on the way. Yes I need all the help I can get but I'm handicapped now because my meter crapped out. I'm just gonna install new gem and wait on my meter to get back from getting repaired. Thanks for all the input so far.
gem on the way?
how do you know anything is wrong with it?
you pooched your meter's fuse
by not using it correctly??
Discussion Starter #17
No I checked the fuse and replaced it just to be sure. It was a older Snap on one. I sent it to be repaired. I have a friend with a mustang salvage yard and got one cheap just to see if it fixes my problem. I will know more in a couple of days.
cheap meter from a friend from a salvage yard?
1 - 19 of 19 Posts
