Hey everyojeni have a 01 gt vert and top is notnworking. What are the stepsnto trouble shoot. Also ebrake when pulled light does not come on but light does work according to key on position. Also there is a double din radio dvd player installed as well. Any help is appreciated.
Need help with this also, i know my pump is good
Need a multimeter or test light. Pop out the switch(top or parking brake mounted) and check for voltage coming into the switch and if it is there actuate the switch and check for output. If there is voltage at the switch but not coming out then probably the switch. If that is OK then you need to check at the pump for voltage. If the pump has voltage then probably the pump. My limited experience with Mustang ragtops not working has been loss of fluid to leakage at the pump or fittings. Hope this helps I am no expert.
