I have a 2000 mustang gt, I was installing s197 seats and as I screwed my last bolt into the floor pan I ran it into the wire splice that runs next to the bottom of the seat and next to the seat belt holder, I broke a wire and ran the bolt into he middle possibly shorting something I went to start it after backing it into the shop with no problems and no fuel the code says drivers fuel pump offline I repaired all the wires and checked all the fuses I blew he pcm fuse which I replaced and changed the fpdm the ifs the ccrm and still nothing I mm kinda clueless I repaired every damaged wire changed he main modules all the fuses under the dash and in the drivers side engine bay box look good what am I missing???
What is the problem now?
