1 - 20 of 31 Posts
Hey guys, I've never had a 2-step but think I understand how it works and I think it would help my high-power stick car.
Does anyone here use one with a stick car?
Can XFI have any 2-step control?
I think I'd like to arm the system by switch (does it have to be a momentary?) and have it disengage when I release the clutch.
Does that sound right?
Any advice appreciated.
-J
I dont know about the XFI but I have the Mallory Hy-fire 6 with a built in 2 step. I have mine set up on a momentary button that also controls the line lock. The 2 step has a toggle so I can still use the button when doing my burnout and then switch it on to hold me at the line. I also have the corded buttons going into a 12volt acc. outlet so when Im not racing the button stays in the glove box. I did that more for the safety issue......My wife is a blonde.....enough said!!! lol
For a turbo 5 speed, it is the way. Don't know about xfi, I use msd's 2 step wired to trigger off left horn button to keep right ready to shift quickly.
I ran a MSD digital 6plus and could build full boost (10psi) at the line. I had to pull a few degrees of timing to get the full 10psi with it set at 3500rpm
I run a momentary switch and the clutch switch to a relay.. push clutch in,push momentary and 2 step is on... turns off once you release the clutch and dont come back on until both the clutch and momentary are pushed in together again.
its nice to have NO buttons to mess with, tried cruise control, windshield washer button and horn. this is much nicer and it dont put the car on the 2step between shifts like running it off JUST the clutch switch.
Excellent sounds like what I want.
Just to clarify, you hit the momentary switch, push clutch in, let off momentary switch and then hit throttle to get on 2-step then the 2-step releases when you release the clutch?
-J
-J
yep thats exactly it.. except for some reason I do clutch first lol lol lol..
I've got mine on a momentary switch that is on my shifter ball. I used to use it for nitrous, but now its a 2step. I would like to run the switch in series w/ a clutch switch. I keep forgetting to let go of the 2step after I launch the car and then the thing falls on its face about 20ft out(hitting the limiter).
Got mine going FINALLY! I only can build maybe 4lbs at 3000 rpms. Dont work to well on the street! LOL
Momentary push button using a relay and clutch switch is the only way to go. You push the pedal down, tap the momentary switch, floor it, then take off!
I'm wondering why these wiring diagrams that get posted always say no line lock...Doesn't anyone with a stick use a line lock and a 2 step? Strange...
There is a really good thread detailing how to do a 2step using the stock clutch wiring and allowing it to release when you let the clutch out.. It uses a relay etc to make it happen
Discussion Starter #15
Yes and that is how I have mine set-up. Both the 2-step and launch setting of the AMS 500 releases when the clutch come out.
I also have a line-lock but have no need to wire it with the 2-step on a manual.
-J
http://forums.corral.net/forums/showthread.php?t=1106140&highlight=step
-J
whats the point of wiring in the line lock... in case the car rolls out and breaks the lights or is there soemthing else to it
thats the only thing I can see it used for, I mean I guess u could use it for the burnout but......
Discussion Starter #18
If you race on uneven starting line tracks some guys need it.
You can do a 3-step as a burnout rev limiter with the line-lock but I don't see the point.
-J
This is going to sound really ignorant. Please don't flame me.
How does a 2-step let you build boost? Does hitting the rev limiter act like an anti-lag?
It allows you to hold the pedal to the flooor and also loads the motor
1 - 20 of 31 Posts
