i have a 306 with a strim running 10lbs of boost,stock t5,fcam,trick flow track heat heads and intake,42lb injectors,what is my car capable of with better 60 foot times
track times
60 ft 2.049,1/8mile 8.402 at 89.37,1/4 mile 12.681 at 118.23
somethings not right tune?
driver?
118 with only a 12.6
something doesnt add up? u should be in the 450-500 rwhp range and knocking down high 10's
MPH is not terrible for first time out. It will probably pick up to 120+ with some more practice. 1/8 mile MPH seems to be down a bit though but that's probably from lack of traction. Even 118mph is good for around 11.40's-11.50's with a good 60 ft. and some fast shifting. Just work on getting that 60 down and banging some gears and you'll improve a ton. What tires are you running?
Same mph here, you must be spining bad or bogging off the line.
60' 1.85
7.89 @91.67
12.08 @ 118
I dont think your gona see 10's with that combo I'd guess he is somewhere around 400's in hp with his combo. Definately not 500 hp. Id say it may see 11.80's
Definately loose the Nittos, run a M/T drag radial or better yet an M/T ET street.
