1 - 20 of 26 Posts
I bought this 1993 mustang notch a few weeks ago, I had two 5.0's in high school and just missed how small and how they handled... since the 5.0's i had a few other cars one of which i still owe 2001 camaro ss. I love the power of the GM LS1 motor's which is why I am going to do this project. Light weight of the fox + the power of the ls1 = ass raping! This will be a slow working project because i plan on buying everything before i take into the fox. Goal is to get a 10 sec pass!
Here is my Bone stock 4 banger :rofl:
Driving her home
Huge parts list
LS1 short block Have
LS1 front engine cover Have
LS1 rear engine cover Have
Ls1 valley cover
Ls1 knock sensors Have
UnderDrive Pulley Have
Crank Bolt Have
Timing Chain
Water Pump
Oil Pump
Oil Pan Have
LS7 Lifters
Ls1 lifter trays Have
Intake manifold
Throttle body
Fuel rails
Fuel rail covers Have
Injectors
Cam
Heads
Head gaskets
upgrade oil pump,push rods, springs
Wiring harness Computer
Cluster
Headers
X Pipe
Cut outs
Mufflers
Tail pipes
Steering shaft
Fittings for Fox's power steering pump
K-Member
A-arms
Spindles
Aerospace drag brakes front
Line lock
Struts/shocks
Springs
Wheels
Tires
TH400
Trans cross member
Sub Frame Connectors Have
Drive Shaft
8.8 Rear end Have
Gears Have
8.8 rear cover Have
Moser axles Have
Mini tube Have
disk brakes for rear Have
93 Cobra Master Cylinder
94-95 Mustang Booster
Adjustable Proportioning Valve
E-Brake Cables
Ladder bar set up
Fuel lines
Fuel pump
Corvette Fuel filter
Roll cage
Race seats
Steering Wheel Have
carpet
Head lights
Tail lights
Radio speakers
Tint
Paint
Parts i bought already:
31 spline trac lok carrier and my gears
went to the junk yard this morning and picked up this rear disc brakes for the rear, need to order a nice set of rear rotors and pads
I ordered my Moser c clip eliminators and Aerospace front brakes, those should be here next week... I would like to work on the rear end this weekend if i have time, i need to get my axle tubes welded, i need to take the rear to my buddy's shop and get that done
rear wheels are in!
I test fit them in my camaro to see how they fit they fit pretty good don't need to grind the caliper like most 15" x 10" wheels do with 4th gen's they do however stick out about an inch. i would love to test fit them in the mustang but im still driving it around using it as a daily i don't want to take it apart just yet
By any chance did you buy this notchback from the whittier area? Reason I ask is because I actually met up with the guy to check it out before I bought it but passed on it due to the tranny seeming like it was starting to slip. Nice project by the way.
Discussion Starter #12
hahaha yes this is the one, trans slips pretty bad but still takes me to work every day, my plans are to buy as many parts as i can, i hope i can get them all by Dec/Jan then start taking it apart paint it and install everything.
Tires are in! i picked them up sat, my baby was enjoying them!
I also took my rear end to my buddies shop to get the axle tubes welded, i would've loved to weld up the cross braces but they have not shown up yet, i am going to have to install that later. We also pressed in my C clip eliminators those are ready to go in... im just wondering if i should wait and get the cross brace welded and also the rear coil over brackets welded in before i oil up the rear? i also set up my front brakes they look great!!!!!
I also got some small parts in
this is the brake pro valve and a hand brake line
Discussion Starter #13
Alright more parts came in, im so close to finishing up the rear its not funny, its another 1G! to finish it up :( still need the discs, pads, upper and lower control arms, coil over spring and shock, and solid bushing.
here is the two rear brake cables for the parking brake
here is the coil over bracket for the rear end, missing the coil over kit
Discussion Starter #15
Yes sorry i forgot to update this forum, i took a break on buying parts during the xmas and new years, i finally took out the motor, not sure if i mentioned on here that i am going LS3 with a 6L80E i sold the ls1 short block i had... i am working on the car every weekend with my buddy here are some pictures i forgot to post on here.
Well i got some more goodies in, i got in my K member, lower front a arms, caster camber plates, rear lower a arms, rear upper a arms, and my anti roll bar set.
i also picked up my seat brackets from a guy on C-list for $40 for both to use with my race seats, great deal, the company i bought my race seats wants $99 each bracket! crazies
Discussion Starter #16
i got my roll cage, that was pretty quick shipping! i got a chromoly 10 point cage, can't wait to install it!!! its gonna look funny as hell in a stock 4 cly slipping ass trans mustang LOL
i got my TB in yesterday ####er was pricy! i noticed that i am going to have to change over to a camaro water pump! the truck one is hitting the TB so i need to get one...
Discussion Starter #18
i threw away the old trans but couldn't throw away the motor, trans was messed up and motor was still good so i put the motor on an extra engine stand just to get it out of the way,
here are some pictures before we gutted the whole engine bay removed front bumper fenders old k member.
Chuy came over and started welding up some holes, we noticed after he started covering up the holes that it would be easier just buying premade panels that covers up all those holes looks much nicer so i will be ordering those panels tomorrow and hope they come in by friday to get hem welded on.
all bones
fenders and front bumper
John was taking care of the dash, i am not going to run a/c or heater so all of that is coming out, my roll cage is a 10pt has a bar that goes behind the dash as well so it had to come out.
we are also going to paint the whole inside black.
Discussion Starter #19
I ordered some engine bay panels instead of welding up all those holes from the engine bay, those should be in next week, i also returned the throttle body, because i will be running drive by wire, I also ordered the brake booster and mc to finish up the brakes parts, i'll post more pictures every week, i am hoping to finish it by the summer
Keep us posted man,................. Real cool build:salute:
1 - 20 of 26 Posts
