1992 5.0 -- What are these plugs on the main harness?
There are two plugs off the main harness, about 4 or 5" from the connector for the ECU -- one gray, one green. They bypass the ECU, and go up under the dash. I have the dash out and thought I could chase them, but they just integrate right into the ignition/light/power harness.
What are they? I was thinking something to do with HVAC, but Those should be part of the power harness, right?
suggest you get a wiring diagram for your car and read carefully
