1991 Mustang Coupe Roller For Sale AKA Stormtrooper
This car is a 1991 GSP SSP Car that has been converted to 1986 Bumpers and Moldings. It is bar none one of the cleanest fox bodies you will come across, especially for one that is setup for extensive track duty such as this one. While the car is ideal for the track it also makes for an extremely smooth street cruiser depending on the engine combo one decides to put in the car.
-Factory Black Interior With Stock Seats
-Rear Seat Delete
-10Pt Mild Steel Cage
-Five Point Harness
-Strange Quick Disconnect Steering Wheel Hub
-Complete UPR Chromoly K Member Kit
-Travel Limiters
-Front Strange 10 Way Coilovers
-Rear QA1 Double Adjustable Coilovers
-UPR Pro Uppers And Lowers
-UPR Anti Roll Bar
-Wild Rides S Box
-Wild Rides Lower Torque Boxes
-Wild Rides Rear Spring Perches
-Aerospace Front Brakes
-Aerospace Dual Caliper Rear Brakes
-Strange Master Cylinder
-Line Lock
-Built 8.8/Welded Tubes/Braces/9" Ends/Mark Williams Yoke
-4.10 Gear
-5/8 Rear Studs
-Spool
-8 Gallon Fuel Cell
-Aeromotive Eliminator Pump
-Aeromotive Fuel Pump Billet Controller
-Aeromotive Filters
-Prolite 350 Fuel Line
-8 Gallon Water Box With Meziere Pump For Intercooler
-Custom Mark 7 Radiator With 4 Fans
-Meziere Radiator Mount
-#16 Line In And Out Of Radiator
-Simpson Parachute
-Weld V Series 15" Fronts With MT Radial Tires
-Weld V Series 15" Rears With Double Beadlocks And Pro 275 Tires
15,000 obo
