1 - 20 of 40 Posts
My car is up for sale again. Has been sitting in garage since last post. Currently not running-- needs engine refresh. Make me an offer! Here is a list of the parts:
Block: DART race
Bore: 4.125
Stroke: 3.250
Cubic Inches: 347
Crankshaft: Scat
Compression: 9.5:1
Rods: Scat
Pistons: Ross custom
Rings: Hell fire
Bearings: Pro Series
Camshaft: B-451
Timing chain: FRPP Double Roller
Rockers: TFS 1.6
Lifters: Crane Tiebar hydraulic
Pushrods: TFS 6.7 chrome moly
Oil pump FRPP high volume
Oil pan: Moroso 7 qt race
Ignition: MSD 6AL
Pulleys: Vortech 6.87/2.95
Crank dampner: Romac SFI neutral balance
Engine mounts: HPM drop solid
Radiator: 3- row
Fan: Spal dual electric 11”
Water pump: Meziere w idler pulley
Miscellaneous Internally balanced
Cylinder head Specifications
Brand & Model TFS Twisted wedge
Valves: 2.02/1.60
Port work: Fox Lake CNC Stage II
Gaskets: Cometic
Exhaust System Specifications
Headers: MAC 1 5/8” long tubes
H-pipe: MAC 2 ½” w/hi-flo cats
Mufflers: Flowmaster 2 chamber
Tailpipes: Flowmaster 2 1/2”
Evac pump and canister: Star/Stefs
Induction System Specifications
Intake: TFS Box Upper
Port work: Port matched to TFS-R lower
T-body: Accufab 80 mm
Mass Air: Pro M 83mm
Air filter: AFM 8” powerstack
Ram Air: AFM power pipe
Power Adder Specifications
System type: Supercharged
Manufacturer: Vortech
Model: V2 Si
Pulley size: 6.87/2.95
Boost: 15-17 psi
Tensioner: AFM billet
Brace: HPM
Fuel System Specifications
Fuel pump: Weldon 2025
Fuel lines: Stainless steel braided/Teflon lined
Fuel rails: Custom billet
Injectors: Siemens Deka 83lbers
Regulator: Weldon
Methanol Injection: AIS Trunk mount with SS lines
Sumped tank/w baffles: Glen’s Performance
Electronics
CPU: Ford 9AL
Computer add-on: PMS w/low impedance drivers
Wide band: Uego
Tach/shift light: Autometer 5” monster tach
Gauges: Autometer water, boost, oil, vacuum, fuel
Drivetrain Specifications
Transmission: TKO-600
Flywheel: Mcleod aluminum
Clutch: Mcleod twin disk
Driveshaft: FRPP aluminum w/safety loop
Axles: FRPP 31 spline
Differential: FRPP 31 spline trac-loc
Gear set: FRPP 3.55
Shifter: Pro 5.0
Chassis Specifications
Springs: Eibach rear/QA1 front
Sway bar setup: Front removed
Subframe connectors: Rhodes custom
Roll cage: Rhodes custom 10 pt
Traction devices: HPM adj uppers and lowers
K-member QA1 with A-arms, coilovers and adj struts
Rims: 5-spoke pony
Tire: MT drag radial
Performance Specifications
Vehicle weight: Stock
Chassis Dyno HP: 635
Chassis Dyno torque: 590
Best 60 ft: 1.72
Best ¼ ET: 10.95
Best ¼ MPH: 134.50
John
Jessup MD tel 240-917-4002
Sounds like a nice build. You are going to take a bath on a not running car with all those good parts. Sell the roller and part it out.
1991 lx coupe for sale
Yes I know; parts alone add up to almost 40,000. I would like to get 16,000. Came from the factory with Ziebart rust protection and garage kept after that. I don't have time to part out
Without a running engine and in a unknown state, you’re gonna be lucky to get 8-10k. It’s basically a roller with a blown motor. Sounds like an awesome car, but just how it works.
And by blown I don’t mean the Vortech! Haha
1991 LX
Your imagination is getting the best of you. It does start and idle. I did not have a catastrophic failure. I suspect that I may have a partially damaged head gasket as I do have some hydrocarbons in the coolant, but it's not frothy. There are a lot of skilled mechanics on the message boards that could refresh the engine and have an instant 9 sec car. I never reached the full potential. I took the car to the track only 2 or 3 times a year. The 635rwhp was with an air fuel ratio of 10 to 1 and 15 pounds of boost.
No Imagination here my friend. Be more specific in you first post. An “engine refresh” is vague and far different from a simple head gasket fix. So as it is based on your first post, ya, I’d say you’d get about 10K. I am a competent member who has turned their car into mid 9 second car. So this isn’t my first rodeo. Regardless, I’m sure your car is great and will make someone happy. Post up some pics and let us see! Maybe think about doing a gasket refresh and get the engine running good and, from the sounds of it, get top dollar. Good luck!!! Bottom line, it’s thought selling these cars.
I’m not a cowboy, I’m from the Northeast. Although I would love to live on a big ranch in Montana. So maybe I am a cowboy at heart...? Anyways, I was in no way trying to be a jerk or be negative towards you. So if there was any confusion, I apologize. I’m not here to be a jerk, just to make friends. Sometimes reading text can cause confusion. I really only posted to be helpful.
Actually, your cowboy joke was a bit funny. I did say something about a rodeo. I’ve never been to a rodeo, I don’t even know why I wrote that!! Ha
Damn that paint is nice.
Very nice. Dark shadow grey?
1 - 20 of 40 Posts
