I bought a 91 LX that was stolen and wiring trashed. A friend has a V8 donor car that I was able to get the column and ignition switch wiring connector. The wires are close to same color, my question is , the 2 yellow wires-what I have found online is they bridge along the way to the column so there position should not mater.The car starts no matter how there connected to each yellow wire. So does it matter on the yellow wires? the airbag wiring from the donor is not the same as the 91 dash wiring connector, thinking cut the connector from the original column adapt. My plan is after inspection and titling install a tilt 89 column. Thanks
Discussion Starter #2
Yellow ignition switch wires
Any opinion on the location of the two heavy yellow wires. See my prior post. Thanks
