1 - 14 of 14 Posts
How much PSI you running did you have the car dynoed/tuned yet?..I cant even cant on my car without it breaking the tires loose at most speeds...lol...Sounds good any pics of the motor?
I can't floor it or Ill go sideways. In the video I was only pedaling it. I have an 11 lb spring in it. No tune yet just locked the timing.
LOL...yeah tellme about it...But i dont have to even come close to flooring it...Mine breaks loose at the touch of the pedal...Is you motor stock?...or worked also plus turbo?...
lol... stock for now just gt40 intake. Not for long though. Sweet spot for this turbo is 16-18 psi. 21 psi max.
if you guys cant get your cars to go straight i think its time for some suspension/tire upgrades!
Im on street tires lol....I didnt mount my DR's yet...once i do im sure it will be a little better ...lol
do suspension before tires.
Before suspension I need my full length sub frames welded in..and a cage..then i can worry about that...lol..I have the front sway bar removed and an old tired suspension..i want to see how i do..I already got it down to 1.8's with Just MT's with a stock long block and my powerdyne before this Upgrade...and that was with 25 psi in the tires.im thinking i can get some 1.7's easy with the mods i have now..And the turbo should pull hard in mid range and top end...So im thinking i can leave lite...and see what happens...
Man I'd be nervous to try to open it up on a packed street like that. mine can get very sideways sometimes. And that's a bad a$$ hood!
1 - 14 of 14 Posts
