Hey everyone,
I have a 89 gt vert, I installed new headlights and decided to try to upgrade to LED lights. I ordered all the bulbs and a new CF13 JL-02 flasher for LED. Installed everything and then BAM! nothing worked. Installed old flasher relay lights come on but no flash (due to low resistance I'm sure). So I thought maybe I had a China eBay special flasher relay, so I ordered another one. Installed today and nothing works again. No lights come on, nothing.
What am I doing wrong? Plugged the new flasher in with the 2 pin connector, grounded the E pin. It should work based on everything I have read. The old flasher relay was a light blue color under the dash near the steering column.
Any thoughts?
you replaced all lights to led?
wrong flasher, should be two pin
sounds like you got the Japanese flasher
or you have the load on the wrong pin
