1 - 14 of 14 Posts
See Ebay listing here:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=230567758332#ht_3310wt_1166
1989 Mustang LX 5.0L FULLY BUILT/RESTORED
This is a 1989 Mustang LX 5.0L Hatchback. I have had the car since I was in high school. The Car got a Fresh Torch Red Paint Job around 2004. I brought the block to my engine builder here, Pro Line Race Engines in Marietta, GA. They rebuilt the bottom end to stock specs, only re-using the factory rods, block and crank. Everything else in the block is new. I got all new parts for the engine. I basically built it for as much N/A power a 306 could make, with the capability of adding Nitrous. I HAVE NOT INSTALLED NITROUS YET! I put the whole car back together with almost ALL NEW parts. I had in the past a 1997/1999 Mustang project that I still had lots of parts lying around from. So I got the bright idea to use all the 1999 brake/suspension parts on this car for the brake conversion. I used the interior parts from the 1997 GT to do a full interior conversion to the new dash. It took MANY, MANY hours of cutting, fitting, fabricating to get all of this stuff to work together. I used the HVAC box from the 1997 and made the A/C lines fit to each other. I used the Steering Column from the 1999 and the brake/clutch pedal assembly as well. I had to re-wire all of the switches/gauges to work with the new stuff. After many hours of labor, I got it all to work. Everything is functional. I took the factory door panels off and built new panels. I made ALL NEW panels. I also re-covered the headliner in much nicer headliner material. I had a new windshield installed as well. The car has a custom built Rear Seat Delete/ Sub Box which houses the Sub box and has a separate compartment which houses the Amp for the sub. This is also a great place to hide a Nitrous Bottle! After I got the car back together and running, I had Jeff Harris at Pro-speed Performance in Powder Springs, GA tune the car. It made 334 RWHP and 336 RWTQ!!!! That’s all out of a little 306! This car is extremely clean, you will be hard pressed to find another fox body Mustang out there this nice, with this many new parts. This car is basically all new! The only real still factory parts include the hard parts like the body and axle housing…..almost everything I could replace I did. Whoever buys this car will be buying an almost brand new 1989 Mustang! Now that I am at the end of this build I regret I have to get rid of this car in anticipation of a new house, I hate growing up! I have well over $20000 invested since just August!!!! I HAVE EVERY RECIEPT FROM THE BUILD, EVERY ONE OF THEM; I CAN SHOW YOU ALL THE MONEY I HAVE SPENT ON THIS CAR, NOT EVEN INCLUDING MY LABOR!! This is a one of a kind Mustang, its clean, its fast and it’s ready for Nitrous! The engine builder tells me the engine can handle a 200 shot of Nitrous!!
Buy this car and save yourself THOUSANDS of dollars by buying the car already built.
The car now only has a little over 6000 miles on it since it was built. This is a beautiful very original car. You will not find another like it for this value. The A/C System was just replaced at the end of the summer, so it is all Brand New! The Tires were just put on also at the end of the summer so they have less than 1000 miles on them.
The pictures show the old tires on this car, it now has Brand New Nitto NT05 Tires installed.
Please contact me via email [email protected] or call me @ 678-362-5685 for questions or for pictures.
$500 Deposit due within 24 hours of auction close via Paypal. Full payment due within 72 hours of listing end via cash or cashiers check or certified bank check to be verified at my local bank. I can assist in getting the car shipped all over the country for an extra fee.
There are no warranties of any kind on this car. I have the title in hand which is clear.
Mod List below:
Engine:
Freshly Rebuilt, Bored .030 over, new everything, bearings, plugs, rings, ect.
Stock 5.0L Block
Stock Rods
New Sealed Power Pistons (stock compression) FLY CUT!
New Comp. Timing Chain Set
New FRPP Lifters
New ARP Head Studs
New Manley Pushrods
New Cometic Head Gaskets
New Edelbrock Victor Jr. Heads
New Comp Cam XE282HR-12
New Comp Cams Pro Magnum Rockers 1.6
Stock Oil Pan
New High Volume Oil Pump
ALL New Gaskets
Edelbrock Performer RPM II Intake Manifold
New FRPP 75mm Throttle Body
New JLT Custom Cold Air Intake
New Professional Mass Air Meter
New 30# Injectors
New IAC Valve
Stock Distributor with new Cap and Rotor and Gear
New FRPP Spark Plug Wires
New Stock Motor Mounts
FRPP SFI Harmonic Balancer
Underdrive Pullies
New Power Steering Pump
New Battery
New Valve Cover Breather Filter
All New Vacuum Hoses, PCV
New UPR EGR Delete Plate
New FRPP Heavy Duty Oil Pump Drive Shaft
New BBK Fuel Pressure Regulator
New Dip Stick Tube
Holley 255lph High Flow/High Pressure In-Tank Fuel Pump
New Fuel Filter
New Serpentine Belt
SCT 4-Position Chip
New PA Performance High Torque Mini Starter
Exhaust:
New Mac 1 ¾” Long tube Headers
New Custom H-Pipe with New Bassani Hi-Flow Cats
New Flow master Cat-Back 2 Chamber with Stainless Steel Polished Tips
New 02 Sensors
Cooling System:
1999 V6 Mustang Aluminum Radiator
1999 V6 Mustang Electric Fan
New FRPP Silicon Coolant Hoses ALL
New Radiator Cap
New Water Pump
New Thermostat
New A/C Retrofit Kit
All New A/C System:
New A/C Compressor with Clutch
All New A/C Lines, New Evaporator
Transmission/Rear-end:
Freshly Rebuilt Stock T-5 with less than 8000 miles
Steeda Tri-AX Shifter with New UPR Shifter Handle
New Spec Stage 2 Cltuch, Stock Flywheel (Only about 800 miles on it)
New Clutch Cable
New Steeda Firewall Adjuster and Clutch Quadrant
New T/O Bearing
Stock Driveshaft with New U-Joints
FRPP 3.73 Gears
The entire rear-end was rebuilt, ALL NEW bearings and seals, differential was also rebuilt
Stock 1996 Mustang Cobra Axles
New Transmission Cross member Bushings
Suspension/Brakes:
Stock Front Control Arms with New Bushings and Ball Joints
1995 Mustang Spindles with New hub Bearings
KYB Struts
KYB Shocks/Quad Shocks
Stock Springs (front and rear)
New UPR Upper and Lower Rear Control Arms
1999 Mustang V6 Power Steering Rack
Flaming River Steering Shaft
1999 Mustang Front and Rear Disc Brake Conversion (Dual Piston Calipers in front)
1999 Mustang Front and Rear Brake Lines
New 1999 Mustang Front Brake Rotors
New Front Calipers
New Front and Rear Brake Pads
New FRPP Caster/Camber Plates
Recently Replaced Tie Rods Ends and Sway Bar End Links/Bushings
1999 Mustang Brake Booster/Master Cylinder
1999 Mustang E-Brake/Cables
Maximum MotorSports Full Length Subframe Connectors
Interior:
Full 1997 Mustang GT Dash/Center Console/Steering Column Conversion
1995 Mustang GT Gauge Cluster
Pioneer Head Unit
New Pioneer Rear Speakers
Clarion Front Component Speaker System
1997 Mustang GT Seats
New Re-Covered Headliner
New Autometer Oil Pressure and Water Temperature Gauges in Dash Pod
New FRPP Leather Shifter Knob
Recently Replaced ACC Carpet
1997 Mustang GT Black Floor mats
New Multi-Function Wiper/Turn Signal Switch
1999 Mustang E-Brake Assembly
All New Re-Covered Door Panels with New Door Panel Boards
Recently Replaced Switches
New Passenger Side Power Window Motor
Recently Replaced Fuel Door Popper
1999 Mustang Clutch/Brake Pedal Assembly
New Door/Trunk Strikers
Viper Keyless Entry System
Exterior:
Torch Red Paint
Recently Replaced Taillight Lenses
Recently Replaced Door Belt Weather-stripping
Recently Replaced Door Handles
New Front Bumper Cover
New Kaneen 3” Cowl Hood
Recently Replaced Headlights/Markers/Corners
New Moldings
New Sunroof Weather-stripping
New Hood Weather-stripping
Recently Replaced Door/Trunk Weather-stripping
New Fender Extensions
New FORD Emblems (front and rear)
New Cowl Panel
New Wiper Arms/Blades
New Door Mirrors
New Door Belt Moldings
New Windshield
Wheels/Tires:
Chrome Saleen Style Wheels 17”
New Nitto NT05 Tires 255/40/17
Mine is the one below. Ive seen a couple different spoilers but never seen a solid one like that. Im new to mustangs so ive been trying to soak up all the info here.
thats just a stock gt spoilers, only the LX cars come with the solid one.
NO, no supercharger.
its on ebay again
How big of a pita was that dash/console/steering wheel swap? Man, I would really like to do that......it looks fantastic!
Discussion Starter #12
The OASIS Guy
THIS....
free bump
any links or info on how to do the sn95 dash swap?
Discussion Starter #14
1 - 14 of 14 Posts
