1989 Mustang hatchback ready to go racing. Has original body with lift off outlaw hood, lift off rear hatch, 8 point mild steel cage,, sw racing aluminum dash, overhead switch panels, quicksilver ratchet shifter, 5 gal fuel cell with braided -10, electric pump, billet filter, adjustable regulator,remote mount battery with cutoff switch. Front end is tubular k member, manual steer rack, front coil overs, drilled front rotors, Weld skinnies, driveshaft loop, 8.8 rear with 35 splined axles,spool, boxed uppers and lowers, UPR sperical bushings,torque boxes reinforced, antiroll bar, Weld Draglites with slicks. Motor is fresh 8.2 deck with forged rotating assembly, comp cam, Edelbrock heads & intake,, new hooker swap , headers, Quicktime 750 carb, 200 shot of Nitrous, MSD digital 6 plus, electric h20 pump, reduction gear starter, aluminum radiator with Flexlite electric fan, Trans is fresh c4 with 3400 stall, billet servo, 6 pinion planetary , red friction clutches, cooler, and aluminum driveshaft. Ran 6.42 , launches straight and hard. More pics and videos available to serious buyer
Stock block?
