hello, im looking to find out what would cause my fuel pump to continue to run after the car has been turned off ? Ive had to disconnect the battery to get it to stop running? Any ideas would be greatly appreciated.
short to power
relay contacts welded
some more I probably could think of.
Could it be a bad relay ? Where is the relay located on an 88 ? Im looking for the most likely place to start . Thanx
start at the eec relay, then move along the circuit to the pump
eec relay is by the ecm, pump relay is under the driver seat
