1 - 1 of 1 Posts
1986 Mustang Police interceptor SOLD!
SOLD!!!!
$14,250.00
Police Interceptor Car: Very nice, fast car. I estimate 550 to 600 horse from my 347 turbo setup on pump gas and 700 on race gas, 5 speed G-Force T-5. Good Silver Paint, 1 year old.
1990 Front End.
I have the original steel wheels that go with the car. I have receipts for most of the parts installed on this car.
I am willing to trade even or down plus cash for an automatic pick-up truck or sell outright. No reasonable offer refused. I need a pick-up truck to tow my drag race car.
Please see the list of parts below:
__________________________________
Treadstone Performance Turbo Kit
76mm Ball Bearing Turbo
Manual boost control
Greddy Blow Off Valve
Electric Muffler Dump Valve
Borla straight through muffler
3 inch exhaust
Trick Flow Track Heat Manifold
75mm Throttle Body
AFR 185cc heads w/upgraded springs
ARP Head Studs
Scorpion Roller Rockers
Hardened Push Rods
Hydraulic Roller Lifters
Lunati Cam #510A8LUN Street/Strip; Camshaft; Hyd.Roller; RPM 3500-6500; Adv.Dur. 292 Int./280 Exh.; Valve Lift .565 Int./Exh.; Lobe Angle 114 Deg.
Trick Flow Main Stud Girdle
Eagle H-Beam Rods
Eagle Steel Crank
High volume oil pump
JE dish Pistons
Fluid Damper
Crank Pulley Spacer
Header Stud Kit
Solid Motor Mounts
Sub Frame Connectors
AEM 30-1400 programmable engine management (Tuneable with any laptop)
RC 71lbs injectors
Autometer Fuel Pressure gauge
Autometer boost gauge
Autometer Pyrometer
AEM air fuel ratio gauge
AEM Electric Fuel Pump Controller
AEROMOTIVE Stealth Eliminator Fuel kit
NOS Kit (150 shot)
Snow Performance Methanol Injection
G-Force T5 Transmission .59 overdrive
Solid Transmission Mount
Steeda Tri-Ax Shifter
King Cobra Clutch
Ford Racing Clutch Quadrant
Moroso Anti-Roll Kit
Ford Racing Aluminum Drive Shaft
.373 gears (rebuilt rear end)
New shock absorbers
Weld Draglite Wheels
Nitto 555 tires (rear new)
NEXEN skinnies (new)
Cons: NO A/C, needs interior work
1 - 1 of 1 Posts
