One Owner
306 Engine, Vortech S-Trim 1- Rib 2.95 Pulley
Heads – Trick Flow – Twisted Wedge
Intake Manifold – Edelbrock 70mm T B
80 Mass Air
42lb Injectors FMU Recalibration 4:1
KB Piston Speed Pro Rings
Bronze Valve Guide Sleeves
5 Angle Valve Job 5/16 Crane Pushrods
Edelbrock Water Pump
Melling Oil Pump
Cloyes Timing Chain & Gears
Trick Flow Spacer Kit 2”
Ford Roller Rockers
Ford E303 Cam Lift 498/498 Duration 282/282
Mac Equal Length Pace Setter H-Pipe
Flowmaster 2 Chamber Dump
MSD Coil, Distributor 6 BTM Box coil HVC
MSD Inline Pump Tank 255 HO Holley
Transmission C-4 Hurst Pistol Grip
Line Lock Hurst Stall 2800
ARP Studs, Bolts
Rearend 8.8 28 spline 3.73 gears
Front 90/10 struts/Rear 50/50 Lift bar Airbags
Cobra R Wheels
T-Rex Inline Pump
Two Step Module
Delay Box
$8500.00
[email protected]
Why is it on a lawnmower trailer? Do you have all the docs where you purchased it new?
Lane
Its not a lawnmower trailer. Its a trailer that was built for my previous drag car. Do not have paperwork from purchase
Not everyone can afford a 30' enclosed goose neck! hehe
A Carfax or Autocheck report will show how many times a car has changed hands if that is what you are looking for, faslane.
