1 - 1 of 1 Posts
1986 Ford Mustang GT - Drag setup but still street legal and driven
Ran 10.3 @ 139 (with 408 and vortech supercharger)
Have all documents, timeslips and most receipts
No Engine
Clear title (owned car since 98')
All items below professionally installed and taken care of.
Selling due to losing job and moving.
Custom checkered Blue and pearl paint job
fiberglass lift off hood
ASP 7" Overdrive 8 rib one-piece crank pulley w/4" underdrive accessories and 3.33" SC pulley
Vortech high volume Aluminum Discharge Tube with Mondo bypass
K&N 9" Air Filter
Morpheus 4" Power Pipe
TKO 500 transmission - 26 spline input
bellhousing setup for 351W
RAM HD Powergrip clutch
351 pressure plate (SFI approved)
351 Damper (SFI approved)
Aluminum driveshaft (mated output shaft for TKO 500)
Aluminum clutch quadrant - fast release
Steeda Adjustable clutch cable
AEM standalone computer for Mustang - fully programmed and setup for Speed Density w/GM MAP sensor
GM LQ9 wasted Spark ignition system (8 coil on plugs)
high volume intake pump(Walbro GSS340 HiPressure 255LPH Fuel Pump) , inline high volume pump, 1/2" braided fuel lines, 5/8 fuel rails, Areomotive FPR
Snow Performance Methanol injection system, boost controller, multiple jets
Compucar Dry Nitrous system, purge, Numerous jets
solid motor mounts
polyurethane Transmission mount
polyurethane cross member mounts
polyurethane power steering mounts (offset)
Trick Flow Tall Valve Covers
1.6 Stud Mount 7/16" Roller Rockers by Summit Racing (15 - one broken)
75mm Throttle body and 75mm EGR plate
FMS Aluminum Driveshaft
FMS Mini-Starter
UPR Smog Pump Eliminator Pulley
93 Cobra Overdrive WaterPump Pulley
ASP/FORD Underdrive power steering pump pulley
3G 130AMP alternator
AutoMeter 5" Monster Tach with shift light
Autometer 2 5/8 Water temp
Autometer 2 5/8 Oil Pressure
Autometer 2 5/8 Volt
Digital boost gage with memory
2 1/8 Fuel pressure gage
2 1/8 Vac/Boost
1 3/4" Full length 351W long tube headers with 3" ball and socket collectors
Custom 3" exhaust
3" 1 chamber Flowmaster mufflers with dumps
Wide Band O2 sensor - setup with AEM
5 bolt axles/drums
5 bolt 11" slotted rotors with green stuff pads
UPR chromoly K-member, A-arms, coilovers w/ 14"-130 springs
UPR bumpsteer kit
UPR chromoly solid upper and lower controls arms
UPR rear anti-rollbar
upper and lower battle boxes (welded)
Steeda full length sub-frame connectors
Weld draglite rims (front 15x6 - 225/50/15, rear 15x8 - 265/50/15 tires)
Mickey Thompson ET Street 26X11.5X15 Tires
Draglite 15X10
Strange 10 way adjustable shocks and struts
Global West Caster/Camber Plates
S&W 8 Point Roll Cage
RJS 5 Point Seat Belts (2)
Taylor Aluminum Battery Box mounted in the hatch – above RR tire
Taylor 150AMP cutoff switch
Completely built 8.8 rear end
3.73 gears
Stange bullet end caps
aluminum diff cover
welded axle tubes
33 spline Moser axles
5/8 studs
9" bearings (welded on) [c clip eliminators]
lightweight spool
140 MPH speedometer
Autometer Electric Fuel Pressure Gauge
Autometer Boost Gauge
A-Pillar dual Gauge Pod
Harwood Pin-on 2.5" Cowl Induction Hood
Aluminum front and rear bumpers
Plastic headlights
SVO Leather Shift Knob
7 quart canfield oil pan w/supercharger drain port
Sony CDX-MP30 mp3 head unit
Sony Speakers 5 ¼ Front, 6X9 Rear
Removed Rear Seat, Carpet Insulation, Front Sway Bar and sway bar mounts, Dogbone, Wipers, Washer tank, heater core, heater hoses
I am selling all parts and items related to this hobby. I have many bins of related parts and previously removed, such as:
wiper motor, seat belts, springs, etc
$7000
can take Visa/MC via Paypal.
Location Uniontown PA 15401
1 - 1 of 1 Posts
