1986 Ford Mustang GT
Up for sale is my 1986 mustang. I believe there were only two owners prior to myself...every internal in the motor possible has been changed... This car drives 100% correct and is a monster in its own. The car needs work and its a great project car. The car will need some body work not much the worst is the passenger floor pan needs repair. Could use a new intereor i pulled the back seat out for a roll cage. All motor work done by previous owner. I have many reciepts from s&k speed. The engine could use a good tune by a performance shop to get the most power out of it. The clutch has about 14k miles on it and the tranny has about 35,000 miles it. It grinds goin into 3rd and i was told that you can fix that by adjusting the clutch quadrent. The motor burns no oil but is missing a valve cover bolt so it leaks a little bit of oil.
The goods-
306ci all forged internals
9:1 Comp
GT40P Heads ported and polished
Ford Racing E303 Cam
1.7Roller Rockers
Moroso 1/2inch Intake Spacer
GT40 Upper Intake
GT40 Lower Intake
Edelbrock Performance Water Pump
MAC Cold Air Intake
Ford Racing 24LB Injectors
Pro-m mass air flow sensor
Ford Racing Valve Covers
Powermaster 160alternator
1600CFM Electric Fan
Ford Racing 9mm wires
New Battery
New Belt
BBK Long Tube Headers
MAC H-Pipe
Flowmaster Cat-Back Exhaust
New Fuel Pump and gas tank
MAC Upper and Lower control arms in rear
Lowering Springs All Around 1 1/2 inches
BBK adjustable clutch quadrent
and more, just can't think of the other things...
MISC Stuff Ill throw in:
Autometer 1/2 inch VOLT Gauge
Extra pcm for 86 mustang
Good fuel pressure guage
AS IS this set up is good for some nice numbers, never dyno'ed it but after you go for a ride you'll see what I am talking about... With a power adder no reason why you can't go 10's... Car has always been adult driven, and never raced... The A/C was removed to reduce lag, but can easily be put back in... The car is blue with a red hatch and hood cause I found a better hatch off a red car.
I would like to get $2500 OBO for the car there is well over 4k in parts alone and another 2k in labor, but the car needs work so i think thats more than fair. Feel free to give me a call 631-681-0294 or email me at [email protected] pics by email only
do you still have this car? I would like to come and see it, I live right in Mt Sinai. pm me if its still available, i'd like to see it this weekend if possible
