1 - 8 of 8 Posts
I hate to sell it but need money.
I have 1 1986 Coupe
Paint is 2yrs old looks good but not perfect, Car is white withe a 4" cervinis cowl hood, SOS aluminum wing, black int, 8 pt roll bar, battery in trunk with cut off switch. Ok here come the fun stuff.
Front suspension- AJE tubular Kmember and a arms,
UPR coil over kit with lakewood struts, 5 lug conversion Weld pro star 15x4
UPR caster camber kit
Rear suspension-
8.8 rear 4.10 gears Moser axles 31 spline full spool C clip eliminators 5 lug axles Weld prostars 15x8 Southside lowers UPR double Adj uppers Torque box reinforcement. Sub frame connectors.
Trans
Art car c4 with reverse manual valve body with Trans brake. Just refreshed this spring, Art car 3500 stall converter. Drive shaft loop FMS aluminum drive shaft
Engine-
393 stroker motor
TRW forged pistons 13.1 comp
Scat forged crank
Cat H-beam rods
Crane flat tappet cam 639 int 658 exh duration 316int 324 exh
Motorsports roller rockers 1.6
Stud girdle
Edelbrock performer rpm head mild port work
Vic jr intake mild port work
Sfi balancer
Holley 750 hp carb flow 850
Arp head bolts
MSD dizzy and MSD 6al with 2 step
Proform electric water pump
Granatelli aluminum radiator with taurus fan
130 amp 1 wire alternator
I am sure i am forgetting some things but if you need more info please let me know Must sell $8500 obo Almost all parts are within 1 yr old. I will email pics to serious buyers only! Thanks Kevin 443 693 3743
Discussion Starter #2
Must sell make a resonable offer
$7500
Where in Maryland are you?
Can you send me some pics [email protected]
I'm very interested.
Pics sent
pics sent let me know if you got them
1 - 8 of 8 Posts
