5.0 block, 327 stroker all forged probe rotating assembly, dome pistons 12.2 to 1 comp, internal balance, pioneer sfi damper, main girdle and windage tray, canton 7qt pan, frpp high volume oil pump, patriot 2.02/1.60 aluminum heads, comp pro magnum roller rockers, studs girdles, afr valve covers, trick flow stage three cam, frpp roller lifters, parker funnel web intake, pro systems 780 dominator carb, granatelli fuel tank insert, msd billet distributor, msd 6al box, msd coil, underdrive pulleys, aftermarket aluminum radiator, black magic fan, mac 1.75 primary/ 3" collector headers, or pro chamber, 3" catback with 3.5" stainless tips, fidanza aluminum flywheel, ram powergrip clutch, astro a-5 bulletproof t5, pro 5.0 shifter, frpp aluminum driveshaft, about 600 miles on trans and engine 8.8 rear with 4.11 trac loc, tubular rear control arms, moog replacement rear springs and kyb shocks, new steering rack and flaming river steering arm have most receipts
87-93 conversion, smoked head lights, 2.5 rr cowl hood,
asking $11,000 will consider trade/cash offers
