I am listing my 1985 Mustang LX Notchback for sale as a roller only.
The car has been high 9's on motor with a all motor windsor and a c4 automatic. 60 foot 1.38 on foot brake!
Please no tire kickers , or test pilots, serious inquiries only!!
I can provide time slips, and video of the car.
Front Suspension/Brakes
90/10 lakewood struts
caster camber plates
Qa1 tubular K member
Flaming river manual rack and shaft
87-93 brake upgrade with 5 lug cross drilled rotors/hawk pads
long studs and open lug nuts
manual brake master cylinder and adapter with
adjustible rear brake proportioning valve and line lock
Ground pounder drag springs
sub frame connectors
drive shaft loop
Rear Suspension/Brakes
Ground pounder springs with air bag
South Side Lower control arms
New double adj upper arms
new rear brakes
Rear
8.8 rear with welded axle tubes
SOS adjustible axle tube braces
trick flow girdle
strange spool
33 spline strange axles with long studs
C clip eliminators, ( one just replaced, other new still in box for spare)
battle boxes welded in upper and lower
Wheels
weld pro stars 15/ 3.5
moroso drag tires
weld pro stars
15/9 5.5 bs
mickey thompson tubes
28 by 10.5 slicks
Fuel system
Holley Black Pump
Barry grant fuel filter
8 gallon fuel cell
-12 braided line from cell to -10
-8 to carb
aeromotive regulator(non return )
Interior
factory dash and pad (black)
factory manual window doors and panels
all factory trim panels
autometer guages mounted where instrument cluster would mount
switch panel where radio would mount
two race seats and covers
drivers seat has custom made bracket welded to bar for seat to bolt to
slider brackets for both seats
five point harness mounted to bar
8 point roll bar
steel wall seperating rear of vehicle from trunk(where seat back would have been) steel rear package shelf with bars through to trunk
custom headliner and carpet with light carpet
apc steering wheel with two buttons
Guages
Autometer sport comp
oil pressure
water temperature
voltage
fuel pressure
transmission temperature
5 inch monster tach
Ignition
msd 6al
msd two step
crane ignition coil
Body
Painted by Perks auto body(Delran,NJ) in 2001
Bright white
orange stripe front to rear (added later)
no rust or body damage and paint shines well
car is garaged at all times
91-93 front nose, fender extensions
4 inch fasten down hood
new front clear light set
87-93 quarter windows
87-93 lx tail lights
SOS sheetmetal wing
Safety
Battery cut off switch mounted where rear lic plate would mount
battery mounted in trunk
just nmra extended tech to 10.0 et or 4/08 when belts expire
I am sure there is missing information, so please contact me
by email or phone with questions or interest
phone-856-304-9911
email- [email protected]
The car is a great bracket race, open comp, heavy, etc drag car
or could be converted to street as well. The tail lights and marker lights
function, headlights will work if bulbs installed.
I will take many pictures and place on webshots at this link
http://community.webshots.com/user/93convt
Price
$4000.00 obo
you will need your engine, transmission, driveshaft
to make complete
