Car was built for NC Street Outlaws Race and is currently Ranked #5 on the Top 10 List. Motor/Tranny have 12 passes on them. Trailer is a 20 ft Sweet Rivers Dual Axle with Electric Brakes. Have titles to car and trailer in hand!
1985 Mustang GT 3000 lb car w/ 180lb driver
UPR Chrome Moly K member kit with caster camber plates and bumpsteer.
Strange 10 Way Adjustable Struts and Shocks
UPR Upper and Lower Control Arms
UPR Anti Roll Bar
Subframe Connectors
Weld Draglites 15x3.5 & 15x10 w/ 28x10.5W Slick
Cowl Hood
Kirkey Aluminum Race Seat and Belt
Programmable MSD 650
Oil pressure and Water Temp mounted in the car
BG280 Fuel Pump
Built Rear with 31 spline axles, 5/8 stud, 3.73 gears (4 Lug)
Steve Johnson NOS kit- Nos Crosshair, Trash Can Solenoid and Fuel Solenoid
Edelbrock Progressive
Power Glide with Pro Trans Brake, ACC Converter, Hurst Shifter
Dart Iron Eagle Block, 4 bolt Mains
Callies 3.25 Crank
5.4 Scat H beam Rods w/ ARP 2000 bolts “347”
CP Pistons 4.125 Bore
Custom Solid Roller Cam
Comp Cam Lifters
Vic Jr Intake ported
Edelbrock Performer Heads, that been worked to the Max.
Cometic Head Gaskets
Comp Cams Rocker Arms
850 Quick Fuel Carb
MSD Dist
MSD Crank Trigger
I'm sure we are missing something. Will try to upload more pictures/videos. Any questions please Message me
13,000.00
