1985 Mustang GT $6500
Due to a move and a baby, I no longer have time and space to have fun with this anymore. Car is a 1985 Mustang GT from AZ so this thing is rust free!
I bought the car back in 2010 from another gentleman that also had been working on it for 7 years before that. So for the past 18 years, it's spent most if not all, of that time in a garage. Car is not perfect but it's come a long way from being a shell when i picked it up. The car does run and drive.
Exterior
85 Mustang GT hatchback
2" Cowl hood
Paint on the body is original. Sun faded on the roof.
Cowl, Rear bumper, & hatch are painted black. Comes with body trim and propper 85 GT bumper
It comes with Fog lights and brackets.
Interior
6 point cage
Brand new carpet
Areo dash
Rear seat delete
Battery box installed but not wired up.
Comes with Uego wideband Not hooked up.
Motor
DSS Level 10 306 short block with gear drive timing set.
Trickflow Stage 1 top end kit
Windage tray & Girdle
Gear drive timing set
Canton 7qt race pan
24 pound injectors 73MM MAF
Anderson power pipe.
Exhaust
Ford racing shorty headers
Bassani x-pipe
pypes dumps
Trans
TKO600
McLeod RST Street Twin Clutch
Hurst Shifter
Rear-end
Welded 8.8
Strange Ford 8.8 Aluminum Support Covers
31 Spline axles with C-Clips
Auburn Posi
Suspension, Brake & Chassis
Through floor subframe connectors
MM K member w/A-Arms
MM Caster Camber kit
MM Steering shaft
Coilovers in the front
Adjustable Strange shocks in the rear
UPR double adjustable upper and lower control arms
Team-Z Anit-Roll bar
SN95 GT Disc brakes both front and rear.
5-Lug conversion
Wheels
1999 GT Rims
The bad.
- Car has been a project so it's not completely done. it still needs some trim pieces installed both exterior and interior of which I do have.
- It doesn't like cold starts due to the cam. once it starts warming up, it will idle just fine.
- It does have an exhaust leak at the ball and socket flange between the driver side header and the x-pipe. I do have a gasket or you can just RTV it.
- Paint is original and when i picked it up it was missing the hood, hatch, and rear bumper hence the off-color. I do have a TON of spare parts that will come with the car.
Looking to get $6000 ObO
Exterior
2" Cowl hood
Interior
6 point cage
Brand new carpet
Areo dash
Rear seat delete
Motor
Canton 7qt race pan
Exhaust
Bassani x-pipe
pypes dumps
Trans
TKO600
Hurst Shifter
Rear-end
Welded 8.8
Auburn Posi
MM Steering shaft
5-Lug conversion
Wheels
1999 GT Rims
The bad.
