1985 MUSTANG GT
4 INCH COWL HOOD
WELD DRAG LITES 15X3.5 15X9 27.00X11.50 QUICK TIMES
9 INCH FORD COMP ENGINEERING MOSER AXLES FULL SPOOL
3RD MEMBER RICHMOND GEAR 4.11 (3,800.00)
DAYTON HEAVY DUTY DRIVE SHAFT WITH HUGE U JOINTS
SOUTH SIDE SAFETY LOOP
SOUTH SIDE LOWER CONTROL ARMS
SOUTH SIDE UPPERS
WILD RIDE BATTLE BOXES
ARTT CAR COMP C-4 REVERSE VALVE BODY WITH TRANS BRAKE
SUPER HEAVY DUTY DRUM, LUTCHES, SHAFT, ETC DEEP PAN
8 INCH 4800 RPM STAHL DYNAMIC
CLOYES TRANS COOLER WITH EARLS BRAIDED LINES
INSIDE
SIMPSON BELTS WITH LOCKS
2 RCI LIGHTWEIGHT SEATS WITH BLACK COVERS
HURST PISTOL GRIP WITH TRANS BUTTON
12 PT CERT CAGE
AUTOMETER TACH WITH RECALL
AUTOMETER ULTRA LITE OIL PRESSURE, WATER TEMP GAUGES
FUEL SYSTEM
A1000 AEROMOTIVE PUMP-REGULATOR
-10AN FITTING TO REGULATOR BRAIDED
-8AN RETURN-PUSHLOCK
HOLLEY BLACK PUMP FOR NOS PRO SERIES REG –8AN
12 GALLON AEROMOTIVE FUEL CELL
AUTOMETER GAUGES 1 FUEL PRESS, 1 NOS FUEL PRESS GAUGE
ENGINE
69 WINDSOR BLOCK MAGNAFLUXED FULLY PREPPED
PROBE 408 HIGH COMPRESSION STROKER KIT
EAGLE H BEAM RODS
SCATT BILLET STEEL CRANK
HIGH COMPRESSION FORGED PISTON 13.8 TO 1
SPEED PRO RINGS
CLEVITT BEARINGS
COMP CAMS SOLID ROLLER 710 LIFT
MELLING OIL PUMP
PROBE MAIN GIRDLE WINDAGE TRAY
ALL APR BOLTS IN MOTOR
CANTON 7 QT OIL PAN
HARLAND SHARP 1.6 ROLLER ROCKERS 7/16 STUD GUIDES
OLD SCHOOL TFS HIGH PORT HEADS (KPI)
FLOW 330 INTAKE 280 EXHAUST WORK DONE BY BENNETT W/FLOW SHEETS
SUPER VICTOR INTAKE FLOWED TO MATCH HEADS CUT FOR STRAIGHT AIR FLOW
PRO SYSTEMS CARB 1000CFM
NITROUS EXPRESS TWIN GEMINI NITROUS SYSTEM
BOTTLE HEATER, PURGE, PRESSURE GAUGE
CONETIC HEAD GASKETS
4 ROW SVO RADIATOR
ELECTRIC FAN
ELECTRIC WATER PUMP
EXHAUST
2.5 INCH WITH 3.5INCH KOOKS HEADERS STAINLESS STEEL
3.5 INCH DR. GAS CUSTOM X-PIPE
3.5 INCH MAGNAFLOW MUFFLERS WITH TURNDOWNS
FRONT SUSPENSION
ANTHONY JONES K-MEMBER TUBULAR A ARMS
90/10 LAKE WOODS
UPR COIL OVER 140 LBS. SPRINGS
STEEDA CASTER CAMBER PLATES
FLAMING RIVER STEERING RACK (MANUAL), TIE RODS, BALL JOINTS
S-W RACE CARS MANUAL BRAKES
AERO SPACE FRONT 4 PISTON DISK
9 INCH DRUM IN REAR
THROUGH THE FLOOR SUB FRAME CONNECTORS
IGNITION
MSD DIGITAL 6 PLUS
MSD DISTRIBUTOR
MSD WIRES
MSD COIL
START RETARD
MOROSO BATTERY BOX
REAR MOUNT ON/OFF SWITCH
140 AMP POWER MASTER ALTERNATOR
EMAIL [email protected] OR CALL 440-365-3668
TRADE OR MAKE OFFER
CAR HAS GOOD OHIO TITLE. CAN BE DRIVEN ON ROAD. THIS CAR WENT 9.59 @ 142.67 1.38 60 FT ON MOTOR.
