1 - 12 of 12 Posts
1985 Mustang Coupe For Sale $2,300
<<<<<<SOLD>>>>>
<edit update>
Ok, need to get rid of this car and will take it in the shorts. Please don't ask to go lower than what I'm listing it at. The transmission alone is almost worth what the total is.
New price - $2,300
Trust me - if you heard this thing run and don't buy it, you will kick yourself! I have no place to keep it when I get rid of the storage unit I'm renting (this month).
This thing was made to look like a POS to run 24hrs of Lemons.
Including an aluminum driveshaft and Pro 5.0 shifter (both not installed)
History - this car was originally a 4cyl car with a 4spd manual tranny and 7.5 rear. Fast forward 1.5 years.
The motor came out of a fuel injected Mustang a couple years ago and has approximately 30k miles on motor.
Motor
Long Block
10:1 306 Roller Motor
TRW 4.030 Forged Pistons
Speed Pro Rings
Stock Rods w/ ARP bolts
Stock Crank turned 10/10
Stock Block Decked, Line Honed, Bored 0.030 over with torque plates
Coast High Performance Hawk Street Fighter Main Girdle w/studs
Clevite 77 main, cam, and rod bearings
Melling Oil Pump
Airtex/Master Brand (O'Reillys) Water Pump
Comp Cams Roller Camshaft
Comp Cams Double Roller Timing Gear Set
Stock FoMoCo Hydraulic Roller Lifters w/dog bones and "spider" retainer
Timing chain cover & stock oil pan
FMS Balancer
Edlebrock Performer Intake
Holley 650 DP
Electric Fuel pump
Billet Dizzy
Cylinder Heads
1970 351W DOZZ Heads
Angle milled
1.90/1.60 Valve Pockets
Mild Port and Polish
Bronze Guides
Manley Severe Duty Valves (Chevy 0.100 long)
AFR 185 Valve Springs
Manley 10 Deg Valve Locks
Manley Steel Retainers
Comp Cams Custom Push Rods (due to angle mill)
Crane Cams Roller Rockers 1.6:1
ARP Rocker Studs
ARP Guide Plates
ARP Head Studs with Reducing Washers
Fel-Pro 1006 Wir-Loc HEad Gaskets (reciever grooves cut into heads)
Flow Numbers 210/145 at 0.600" and 28" H2O
Drivetrain
Brand new from Tommie Vaughn Ford T5-Z with less than 200miles on it.
Stock shifter
Stock driveshaft
New OEM clutch
New clutch cable
Flywheel came with motor since it was balanced with it.
8.8 Rear with 3.73 gear and Ford Racing 5 lug axles w/long studs
Body
It's not pretty, but this was the original intent with the car to begin with. Ask me about why and you will understand. The motor was painted to look old and nasty, but is very "bling".
Did some floorpan work (plates) due to rust
Body is in excellent shape, but does need to be sanded and painted.
No headlights
No interior except for dash (again, was going for the "trashed" look)
Kirkey aluminum racing seat
5pt racing harness
Window net
AutoPower 10pt bolt-in cage
Windows have been removed - have the windows in needed
Comes with extra trunk lid
Small tach on steering column
Shift light on rollbar
Heavy Duty radiator
Clutch Fan
180* Thermostat
Windshield wipers work!
Brand new 3G alternator with correct wiring harness (not butchered)
Brand new battery
Stock headers
H-pipe w/bullet dumps
Hard to find dual snorkel air cleaner assembly w/stock air filter
Suspension and Brakes
93 GT front control arms with road racing bushings + brand new spindles with long studs (5 lug)
V8 front swaybar
Road racing springs 950lb front 300lb rear
Stock struts and rear shocks
2001 Mustang GT calipers and rotors
Drum brakes in rear
Has Toyo RA-1's on 16x8 rims
This car is so much fun on the open track and do have some videos of it beating up on real race cars and other not so much real race cars. Can also be converted to drag racing with spring, strut and shock change. Super fun and this thing screams!!
I was able to add some pictures to my gallery.
yes please post up some pics very interested....:)
edit: See below post for pics
Woot! Can post pics now.
Again, the motor was painted with the intention of making it looks really <cough> old.
Motor running: Motor revving (2meg)
New Price!! <read original post for updates>
email me @ cmc17 at tek-racing dot net
Trades? Offers?
I got a PS3, Mavado Watch, and 32" 1080p LG flat screen..
Sale Pending
Discussion Starter #12
<<<<SOLD>>>>
1 - 12 of 12 Posts
