1 - 9 of 9 Posts
1985 Ford Mustang GT
THIS 1985 FORD MUSTANG GT HAS A 10 PT CAGE. THE CAR HAS BEEN CONVERTED TO EFI W/ PAINLESS HARNESS. 1989 302 W/ EDELBROCK PERFORMER O-RINGED HEADS 1.9/1.6 VALVES , TRICK FLOW STAGE 1 CAM (.499 I / .510 E), 1.6 ROLLER ROCKERS, ZEX NITROUS UNIT W/ BOTTLE HEATER & PURGE. CLEAR TITLE, CURRENTLY TAGGED AND INSURED.
$8400.00 / BO or
PARTIAL TRADES ACCEPTED:
24' ENCLOSED CAR TRAILER
CALL 302-659-3793
NEW
DOOR OUTER BELT W/S & MLDG
SUNROOF GLASS W/S
DOOR W/S LH &RH
REAR HATCH WEATHERSTRIP
DOOR JAMB LIGHT SWITCH
DOOR RUN W/S LH & RH
5.0 FENDER EMBLEMS
FORD TRUNK EMBLEM
LOCK CYLINDER GASKETS
MUSTANG GT HATCH DECAL BLK
OTHER INFO
DRIVESAHFT LOOP
FIRE EXTINGUISHER
PAINLESS EFI HARNESS
SUMMIT LINE LOCK
RACE SEAT & COVER COMBO
SUMMIT BATTERY CABLE KIT
SUMMIT BATTERY BULKHEAD CONNECT
SUMMIT BATTERY DISCONECT SWITCH
HOLLEY 255 LPH FUEL PUMP
VORTECH T-REX IN-LINE FUEL PUMP
CUSTOM INST. PANEL
AUTOMETER SPORT COMP GAUGES
5" TACH 8000RPM
5" SPEEDO 120 MPH
PRO COMP FUEL PRESS
FUEL LEVEL
VOLT GAUGE
WATER TEMPERATURE
OIL PRESSURE
VACUUM
LOKAR SPEEDOMETER CABLE
RJS 5 WAY HARNESS
COMP ENG SUBFRAME CONNECTORS
3" COWL HOODSCOOP
COMP ENG 8 PT ROLLBAR
HOLLEY 255LPH FUEL PUMP
MOROSO BATTERY BOX
UPR BIG MOUTH AIR FILTER
A9P COMPUTER
LINE LOCK
OPTIMA RED TOP BATTERY 800 CCA
MAC CATBACK W/ 3” SS TIPS
UPR OFFROAD X PIPE
WELD DRAGLITE 15X5 w/3.5" BS 4 LUG
M/T SPORTSMAN TIRES 26X7.5-15
MCGUARD LUG NUTS
WELD DRAGLITE 15X8 w/5.5" BS 4 LUG
BFGOODRICH RADIAL T/A P245/60R15
FRT & REAR 3" MOROSO WHEELS STUDS
TRANSMISSION
PROFORMANCE TRANS C4 REBUILD FWD MANUAL V/B,
5 CLUTCH DIRECT DRUM, WIDE PMP BUSHING,
RED LINED H.D. INT. BAND
HUGHES LOCKING DIPSTICK TUBE
PERF AUTO DEEP ALUM TRANS PAN
ALUM SERVO
TCI 11" CONVERTOR
B&M TRANS SUPER COOLER
HURST QUARTER STICK SHIFTER (FWD PATTERN)
6AN BRAIDED TRANSMISSION LINES W/ 6AN FITTINGS
ENGINE
RUSSEL EFI 6AN & 8AN CONNECTORS
FRPP A/C ELIMINATOR KIT
POWERMASTER RACE 100 AMP ALT
CRANK & WATER PUMP UNDERDRIVE PULLEY
TCI FLYWHEEL 50oz 157T
FRPP SHORTY HEADERS
REAR
8.8 REAR W/ FRPP 3:27 TRACTION LOCK
UPR PRO SERIES SPHERICAL BUSHINGS
UPR DOUBLE ADJUSTABLE UPPER CONTROL ARMS
LOWER CONTROL ARM BOLT KIT
TUBULAR LOWER CONTROL ARMS
UMI UPPER TORQUE BOX REINFORCEMENT
1985 ford mustang GT
car is back up for sale $8400.00 /bo will also sell as rolling chassis $5300.00 /bo located in Delaware (302)659-3793
STREET LEGAL. JUST PASSED DELAWARE EMISSION TEST. FUN TO DRIVE. TAGGED FOR ANOTHER YEAR..............
1 - 9 of 9 Posts
