Ford : Mustang GT in Ford | eBay Motors
Make offer on ebay very negotiable!
The GT350 has :
- 1994 351 W roller block short block
- Factory lockable T-tops (with keys)
- Ford accessory rear window louvers
- 2003 Mach I five lug wheels ( 17 x 8)
- Front tires are Dunlop SP Sport 9000 235/45/17
- Rear tires are B.F. Goodrich Comp T/A ZR 255/45/17( look almost new still)
- JVC cd player ( with remote)
- Hurst shifter
- F303 cam
- Canton 7 qt oil pan & pickup
- Melling high volume oil pump
- AFR 185 aluminum heads with roller rockers, guide plates and hardened pushrods
- Edelbrock RPM Air Gap intake
- Holley 750 carb
- K&N air filter
-Ford Racing wires
- MSD 6AL ignition, blaster coil
- Holley red electric fuel pump
-1 wire alternator
-optima battery
- BBK shorty headers & H-pipe
- Mac catback exhaust
-Spec stage II clutch kit
- Adjustable clutch cable, quadrant, and firewall adjuster
- Cobra spec T5 trans
- Energy Suspension polyurethane motor mounts & trans crossmember mounts
- subframe connectors ( with seat bolt braces)
- 3:73 gears with 8.8 rear
- underdrive pullies
- 94-95 front spindles, disc brakes
- 94-95 rear disc brakes, adaptor brackets for rear brakes, stock foxbody length axles
- front and rear brake rotors drilled and slotted
- 4 core radiator
- electric fan
- Ford Racing blue silicone hose kit
- Ford Racing aluminum driveshaft (not installed) but included
- Redline Hood and Hatch lift kit
- Dash matt
- 3.5 shorty antenna
