Status
Not open for further replies.
1 - 1 of 1 Posts
1984 1/2 MUSTANG GT350 I BOUGHT FROM THE 1ST OWNER IT HAS 50,000 I TURNED IT INTO A DRAG CAR . CAR IS MINI TUBBED NOT CUT UP HAS ALL NEW EVERYTHING .NEW REAR END 35 SPLINED AXLES , NEW LIGHT WEIGHT SPOOL, NEW AERO SPACE BREAKS, 4.88 GEARS, TUBULER UPPER AN LOWER CONTROL ARMS ADJUSTABLE, FRONT END UPR K-MEMBER COIL OVERS ,NEW AEERO SPACE BREAKS ,NEW BREADED LINES , 12 POINT CAGE ,SUB FRAM CONNECTORS , POWERS WINDOWS AND LOCKS STILL WORK , NEW 5 GALON FUEL CELL ,NEW QUICK FUEL PUMP WITH REG IN REAR ,BLACK -8AN FUEL LINE NEW 2 SPEED POWER GULID WITH TRANS BREAK , 6200 CONVERTER , HURST PISTAL GRIP SHIFTER, NEW DOM DRIVE SHAFT 1350 END . 7 SWITCH PAINLESS WIRING ON ROLL CAGE , ALL NEW GAGUES , 7AL BOX, NEW 2 ALUMINUM KIRKEY SEAT WITH NEW CLOTH COVERS , NEW RUG , MOTOR COMPLETLY NEW ONLY DYNO'ED 2012 BOSS 302 BLOCK ,NEW CRANK ,RODS, NEW EDELBROKS VICTOR JR HEADS PORTED & POLISHED BY CHAPMAN RACING THEN SENT THE NEW PARKER FUNNELWEB INTAKE TO ADAM MANCHESTER IN MASS TO PORT BOTH OF THEM MORE .NEW QUICK FUEL 950 CARB .NEW VACUUME PUMP NEW ELECTRIC WATER PUMP NEW T&D SHAFT ROCKERS TITANINUM VAVLE TRAIN NO EXPENCE SPEARED MOTOR MADE 625HP ON THE DYNO IT WAS BUILT BY NAT'S RACING ENGINES IN MASS, NOT ONE USE PART ALL NEW EVERY NUT & BOLT NEW HOOSIER TIRE FRONT & REAR NEW WHEELS WELD DRAGLIGHTS 10 HOLES IN REAR 15X10 NEW BILLET SPECITALS BLACK ANIADIZED 3.5 UP FRONT AND NEW 26" TIRES . CAR NEEDS TO BE ALIGNED AND SCALED THEN RACED .SHOULD RUM 9.60'S ALL OUT , ALMOST FORGOT IT ALSO HAS A NEW MEGA 450 BOX AND A NEW TS1 THROTTLE STOP FOR 10.90 OR 9.90 RACEING IN CLASS ,, 20,000 FIRM
ALSO HAVE A 24 FOOT HAULMARK WHITE TRAILER ENCLOSED 2002, 4500$$$
AND A 1997 FORD F350 EXTENDED CAB DUALLY FROM LA, JUST 200,000 2 WHEELDRIVE POWERSTROKE DESILE MINT NO ROT 6500,00
1 - 1 of 1 Posts
Status
