Fore sale, 1981 Mustang coupe project car. EVERYTHING goes with it. car was converted to an aero nose. Some pictures and a list of parts.. $4500 obo, looking to get rid of this ASAP, come pick it up if you want it. Cash or paypal.
TA Performance 8.8 Rear end girdle
D&D coil over conversion (front)
D&D CC plates.
16 gallon fuel cell with fuel level sender. Summit part # SUM-290108
Already installed, UMI performance upper and lower torque box reinforcements.
Energy suspension motor and trans mounts
Holly 750 double pumper carb
autometer 5” tach and speedo, and other misc gauges..
UPR upper/lower rear control arms installed.
373 gears installed.
Kooks 1 5/8” x 3’ long tube headers for gt40P heads.
subframe connectors already installed.
flaming river manual rack.
3” X-pipe from summit racing, part # SUM-642130
battery box, SUM-G1200A
Valve covers, SUM-G3322
fuel system, hoses, misc fitting pump and filter.
fuel pump summit part # MAA-4140
MSD distributer part # MSD-8579 and bronze gear MSD-8583
QA-1 tubular K-member with tubular front control arms, already installed.
S&W 8pt roll bar partially installed.
NOS system
Quick time bell housing
T-5 transmission.
Aluminum driveshaft
ron davis aluminum radiator
MSD 6AL ignition.
16” pony wheels (4 lug) with tires (need to be replaced)
17” 5-lug wheels off of a 99 mustang gt
5-lug spindles for conversion.
New brake lines.
4” HO Fibertrends cowl hood.
driveshaft loop
oil pan.
a slew of other misc things..
Motor, Stock 302 bottom end with a motorsport E-cam, and ported GT40P heads and stud mount rockers.
Edlebrock victor jr intake drilled and tapped for direct no2 injection.
