Posting this for a good friend, he is selling his 1980 Mustang Coupe. Best bet is to call if you are interested, number is at the bottom.
Car was originally a grudge car so engine details/times will be provided to serious parties, the rest of the car is detailed below.
The basics of the motor is 351w with heads, internals, and all the goodies.
Powerglide with JW bell and 1.80 straight cuts - the trans needs to be gone through. Burned up the first gear band. Rest of the trans is fresh. Just don't have the time or desire to fix it and want the car gone.
Rear end is an 8.8 that's been narrowed. 35 spline axles and spool with 3.73's.
7531 ignition with crank trigger and ICT. ARC 8000 panel
Car has an 8.50 mild steel cage. Its been mini tubed, still stock suspension with coil overs all the way around. Lakewood 90/10s up front and single adjustable QA1's in the rear. Car has been mid 1.2X's on 28's.
I am sure I am missing a ton of small details, but if you're interested call the number at the bottom.
Not looking for trades. Cash is king.
My friends number:
815-323-0040
Price:
$13,500
Nice car. Janesville here and will be back home on February. If it is still available I would like to drive down and see it.
