1 - 1 of 1 Posts
1980 Hatchback Mustang with 5.0 liter engine and 5-speed transmission. New parts: High volume water pump, hi-flow thermostat, serpentine belt, urethane motor and transmission mounts, tie rod ends, power steering rack, clutch cable, clutch quadrant, plugs, rotor, distributor cap, all weatherstripping, rubber radiator mounts, all rubber cooling lines, all rubber fuel lines from the tank to the carb, the rubber vacuum line to brake booster, and the battery.
It has the 10-hole, 4-lug 15" GT wheels with Goodyear Eagles.
Car underwent a complete disassembly and painting in the 90's. All sheetmetal including interior was painted.
Includes a cover and some original parts.
MUST GO! Purchased another toy and need more space. $3950 OBO
Will consider trade for motorcycle or golf cart PLUS cash. Thank you.
1 - 1 of 1 Posts
