needs it restoration finished great project for the winter
selling it because we are having our 2nd child.
$4,000
1965 ford mustang
Originally a 289 c4 auto
Black interior
61,000 original miles
Antique tags
Currently 302 c4 auto 50oz balance
Front End
New Front shocks Comp engineering
Upper and lower ball joints
New lower control arms
Spindles reconditioned
New inner and outer tie rods
New slave link
New idler arm
New pitman arm
New Steering box
New spring perch
New brake shoes
New brake hardware
New wheel cylinders
New wheel bearings and caps
New master cylinder
Wiring
New under hood wiring harness
New head light wiring harness
All electrical items work perfectly
Engine
Rebuild 302 4 bbl engine
C4 auto transmission
130 amp power master alternator one wire
65 289 cylinder heads for more compression
Hooker comp long tube headers
Meziere Water pump
Pertionix ignition
New speed o cable
Summit 4 barrel aluminum intake
Original gold valve covers
Original gold air cleaner
Needs timing cover and damper installed to run
Original ford 3 row radiator
All new upper and lower radiator hoses
Monte Carlo bar
Export brace
Rear end
New rear Leaf springs
New rear shocks Comp engineering
New 8” rear end needs rear brakes completed
New intermediate brake hose block
Sub frame connectors installed
Interior
New window regulators and rollers installed
All interiors pieces restored
Need carper and headliner
Seats all in excellent condition
Shifter has been rebuild with all new bushings
Radio is a new style digital unit that looks like the old one dash is not cut
Floors are in decent shape
All glass is original
New ignition switch original ford keys
Glove box door is original and restored
Glove box interior is restored
Exterior
New gravel shield
New upper valence
New lower valence
New grill
New pony and corral
New bumper supports
New chrome bumper
Doors are in excellent shape drives has been re skinned
Quarters are ok could use some work
Comes with everything for the body except the hood
New ¼ trim
Both fenders are original ford not reproductions
I
Extras
1965/1966 Shelby race fiberglass nose
Automatic brake pedal assembly
Generator for a 1964 ½ mustangs
1965/66 repo fender
Needed to complete
Timing cover and water pump installed
Front brake lines
Rear brakes installed
Fuel tank installed
Carpet and headliner
http://s330.photobucket.com/albums/l424/jgehret141/65%20mustang/
