1 - 17 of 17 Posts
With standard length 5-lug axles you would use SN95 offset wheels, if you use SN95 axles to do the conversion, you would need S197 offset wheels on a Fox.
cheers
Ed
Old thread new question. With the drum sn95 spindle 5 lug conversion will the 9s fit without removing quad shocks? Is fender rolling or anything else required? Thanks!
Reviving this thread because I bought the sn95 specific 18x9 and 18x10 wheels because I'm using refurbished '94 spindles and the bore on the wheels isn't big enough to clear the hub. All 4 wheels have the correct back spacing, yet the hub bore is somewhere around .03" too small.
I'll probably just take a dremel to them but thought it was pretty odd they don't fit the spindles they're made for.
1 - 17 of 17 Posts
