Before the NX fuel cell the normal size did great. (Yes I have the vacuum set)
70 N02
38 Fuel
Now for some reason its rich tried lowering fuel pressure didn't help.
Anyone had this problem?
Is anyone running this setup and can tell me the Fuel jet they are using?
Car is apart and would like to get this fixed before I put it back together. (have to pull the intake to change jets)
I'm going to change the Nitrous Solenoid.
I take it you are using pretty high fuel pressure ?
I use 6 lb. flowing,and a 10 jet spread on both kits.
Dirty nitrous filter ?
Do you have good bottle pressure ?
Factory 38-39psi
Is that carb?
No filter
Yes good bottle pressure
Yes,i am carb.
No filter is asking for trouble. Small solenoids are easy enough to gunk up.
I used filtered fittings on motorcycle setups and was shocked at how much trash I would find in them.
I use a full sized filter.
