i hate asking these, but i need to know, i got called out today by my cousin who has a s10 with a decent 350 that i built, i drove it several times and it just does not impress me at all..just not enough gear, to big intake and tall tires..etc..anyway my car is set up for 1/8 mile , 302 ci..it has heads that flow [email protected] has a rpm air-gap..670 avenger ..msd stuff..no ac..air..heater box..cam is a E cam and 4.88 gears with et streets 26 inch tall..c4 tranny with a 3200 converter..his truck ran 12.60s in 1/4 mile.before he blew it up and i built his 350..same motor just added a solid cam..its a turd...but we are running 1/8 mile ..im thinking he is going to get his a.s.s handed to him
7.0-7.2 for your car, your intake is hurting you. You should be running a Victor Jr...
As for his, I cannot give you any accurate prediction. Its hard to tell unless you got better details other than a 350 with a solid roller. Be warned though, them 350's can throw out some serious power.
its a solid flat tappet cam...big partoit heads..230cc runner 2.08 valve..almost 12-1 compression..big team g intake and a 750 demon..his cam is 2700-7400 rpm..he has 28 inch tires with 3.73 gears ..turbo 400..it shift automatic at 6500 no matter what..its a turd..need way more gear and shift higher but he will not shift it more then 6500..hell it has a forged crank and h beam rods.. i drove it for a week before i turned it over to him, tuning it here and there..first gear is hell..then it takes forever to get the rpm back up..
Doesnt sound like no turd, should be putting out 500ish at the crank...
Have you ran your car? You never said what your car runs, unless I missed it. If it comes to it tree the hell out of him and if you don't think its gonna be enough, you are the tuner, its amazing what a loose spark plug or a bump in timing will do. lol
never had it out..just got it done
