Is this swap possible or has anyone tried it? I searched the old interwebs but didn't come up with anything. I would be using the DCC controller for its operation, if that matters.
does it even fit?
does it even fit?
The dimensions I found for the 05-14 fans appeared to be compatible with the fox radiator e.g. SVE radiator. Of course, some kind of brackets would need to be fabricated but that's ok, I have an SN95 fan on there currently and I had to make brackets so it could fit, so that's no biggie. My big concern is if it would fit with the aforementioned modifications to be adapted to the radiator and if the available fan controllers would be compatible with it as well. I have a DCC controller but I am also unsure it will be compatible.
if it actually fits, that is good.
as for controlling it, that is no biggie
you create the sequence of operation, and design the wiring to accommodate it.
