I'm trying to complete my swap from auto to manual and I need the computer from a 5 speed car to complete it. I contacted Brenspeed to see if they could retune it, but they told me that I would need to purchase an ECU. If you are parting your car, please send me a message and how much you want for the computer.
thanks
LB
FWIW, you'll need a computer that is compatible with your year model. If you have a '06, you'll need to get a '05 or '06 ECU.
The '07+ ecu's have different pin assignments, so DO NOT try to use one, unless you also change the engine wiring harness. Stick to a '05/06 ecu, and you'll be fine.
And there's some mod you'll likely need to make to use the auto wiring harness with a manual ecu (simulating clutch pedal switch).
(I do have a '05 automatic ecu for sale, but that doesn't help you.)
thanks for that info! Didn't realize there was a difference between them.
so it looks like I need an 05 or 06 ecu
LB
Still need a computer.... Anyone know where to get one at a decent price?
