88 GT Wheel Fitment - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 07-02-2004, 04:04 PM Thread Starter
88 GT Wheel Fitment
Is there a FAQ anywhere on fitment data?
I have a set of 17x9 20mm offset Cobra R Wheels to put on my car. I need to know my tire options, it seems as though there is great controversy. The car has KYB Shocks, and Ford Racing C Springs. I dont' want to have any issues with rubbing.
255/40/17 ? 245/45/17? 275/40/17?
Thanks for all the help!
RacingRosey is offline
post #2 of 3 Old 07-02-2004, 09:06 PM
1 Bad 88 GT's Avatar
I had R's on my 88 with 245/45's up front and had no rubbing other than at full lock. The remedy? I just didn't turn as sharp anymore. I had 255/55/17's in the rear and had to roll the fender lip, educate the inner fender with a BFH and flipped the quads. I did the same on the 89(275/40's all around). The 80 LX(exact same rims/tires that were on the 88) required more attention to the front fender since I relocated the K member forward 3/4" so I had to roll the fender in front of the tire as it made contact only when turning.
89 5spd Coupe, 351C EFI Spyder, QA1 tubular K-member, 5lug conversion, 13" PBR calipers, 17x9 95 Cobra R's, AGS 4.1 suspension.
80 LX hatch, 351C w/GForce T5, 750 Speed Demon, 11:1 cr, 1 7/8" Hedman Huslers, custom X-pipe, 2 1/2" Ultra Flo welded, QA1 tubular K-member, 5 lug conversion, 17x9 95 Cobra R's, 3.55's
1 Bad 88 GT is offline
post #3 of 3 Old 07-29-2004, 03:46 AM
88cobaltblue's Avatar
Hey racingrosey I just put this on my car with help from the guys here at corral. take off the quad shock and put some good aftermarket lower control arms and you will be fine with all of those sizes.
-Ivan
1988 Mustang GT-.40 over,vortech 17psi,efi spyder intake,jegs/kaase heads,Cometic gaskets,E303 cam,all forged internals,1.6 scorpion rr,38lb injectors,70mm throttle body and spacer,77mm MAF,bbk longtubes w/bassani x-pipe,SPEC stage 3 clutch,msd coil and 6AL,Proform electric fan,275/40/17 nitto NT 555R drag radials
thinking about a 75 shot
2000 SVT Lightning-4lb pulley,predator,JLP forced air induction,SVO single blade throttle body,bassani catback exhaust,305/95/18 nitto 555R drag radials.
88cobaltblue is offline
