Blow thru Mass air - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 02-24-2008, 11:18 AM Thread Starter
Blow thru Mass air
Im putting a turbo setup on my 92 lx. Its the stock block with a 76mm turbo w/10lb wastegate spring. Im goin to be running 42lb injectors w/255 fuel pump. Just wondering If i need a blow thru mass air and where i can get a good one.
ForcedInduction5.0 is offline
post #2 of 6 Old 02-24-2008, 11:54 AM
red89coupe's Avatar
Trader Feedback: (31)
Well if you maf is between the turbo and intake you NEED a blow thru.. IF its between the air filter and turbo ( air inle) then its Draw thru.
I run a 3inch PMAS pro tube maf calibrated for 42s and blow thru turbo. got it at JDs for like $260 shiped
red89coupe is offline
post #3 of 6 Old 02-24-2008, 10:30 PM
NC STANG GUY's Avatar
Trader Feedback: (176)
About the same here. I run a 3" PMAS pro tube for 60's I got from JD's. Best price I found.
http://www.jdsperformance.com/index....=item&inmake=0
NC STANG GUY is offline
post #4 of 6 Old 02-25-2008, 12:20 AM Thread Starter
If i was to buy a PMS programmer wouldnt that take the place of the MAF?
post #5 of 6 Old 02-25-2008, 01:04 AM
Doesn't that piggy back the stock ECU? If so then you'd still need a MAF unless those things are Speed Density systems(but being a "programmer" I kinda doubt that).
mfpmax is offline
post #6 of 6 Old 02-25-2008, 01:47 AM
Being a '92, your car should be mass air, so you'll still need a MAF with the PMS.
SonicFox is offline
